Stick
What thickness plate did you use ?
Kaczman said:I got the passenger side UHMW polyethylene skin in place today.
Stick said:What thickness plate did you use ?
Kaczman said:The original sill plates and vertical floorboard area were re-enforced with 3/16" plate, and the new rocker is 3/16" by 5".
Look in the yellow pages under "Plastics". I think I paid around $40 for enough material for both sides.HTeK said:where does one acquire large peices of this stuff?
Cut out the old rockers, weld in the new steel, paint, tap holes for the UHMW, bolt up UHMW. I rarely make any plans for any mods I do. I just cut the old beat up pieces out, and try to replace them with something more durable, efficient and trail worthy.big cherokee said:any plans on them you get get me and what are they made out of
Jes said:Well, after the Fordyce/Rubicon run I'm sold on the stuff. About time I replace my bashed in rocker skids anyway.
JeepFreak21 said:You gonna put new aluminum/metal down first and skin it with the plastic?
Billy
JeepFreak21 said:I was wondering if it'd be possible to coat or wrap the driveshaft in this UHMW stuff. I tried to find it in some sort of spray, but couldn't come up with anything.
Billy
JCSXJ said:That would be cool but, I think you would actually have to put your shaft in it while it's still a liquid and let it cool to your shaft. Maybe make a mold, put the drive shaft in it, pour in the UHMW and let it cool and harden.....
Good luck getting that shaft to balance, though. Cant exactly weld washers to the plastic. Maybe feet upon feet of zip ties in strategic areas?? :viking:JCSXJ said:That would be cool but, I think you would actually have to put your shaft in it while it's still a liquid and let it cool to your shaft. Maybe make a mold, put the drive shaft in it, pour in the UHMW and let it cool and harden.....
lankchevy said:sorry to drag up an old thread, but i have some questions, after cutting out the rocker itself, did u have do u anything to the acculay floor pans to get the boatsides to fit right? and if u could do it over what width metal would u use?
kolby
