GrimmJeeper
- Gardena, CA
the AN adapter fittings screw right into the trans and then you just run a 90° elbow that goes from AN to hose barb. simple, quick, and easy to disconnect if you need to pull the trans. plus they won't leak like those stupid quick disconnects do if the plastic retaining clip isn't seated just right. search for the thread about replacing the quick disconnects I did in mod-tech, all the part numbers are there with lots of pics.
EDIT: here you go http://www.naxja.org/forum/showthread.php?t=1045807
