xplorer7234
- McChord AFB, WA
any help on this would be greatly appreciated, i have a 90 xj, its pretty big pos but its my lil project, and about a week ago i went and got an emissions test on it and failed pretty bad, but any ways changed plugs wires, fuel air, and oil filter along with fluids, but anyways to my problem right after that, as soon as my battery is hooked up my fuel pump starts up and i get pressure in my fuel line, and it will eventually drain my battery, so my initial thought was it to be a relay and i pulled every relay i could find hooping it would stop and no it didnt, so then i was think the ignition lock cylinder was fucked up thinking that its stuck at on and not off, but before i go and take all that off i was hoping to see if any body had any better ideas or anything really any kind of help even with removing the steering wheel because i went to take it off and one of the bolt hole threads are stripped out,
