XJRocket
- Beaverton, OR
Since I am a mustang guy as well as a jeeper, I realized that if we can use cobra brakes with a WJ knuckle, Then it also means we can use these as a bolt on from the 2000 Cobra R.
never heard of the cobra brakes either.. just sport trac. more infoz plzzz
I also noticed the ford motorsports kit is the same kit as the brembo GT kit. It includes 13" rotors and the same brembo calipers, but only $1300.
I'm curious if wilwood carries a kit as well.
...can lock up 35's.....
All you need to do is use a rear disc set up.I have stock 88 Renix rotors/calipers /pads,BUT use an Explorer rear disc set up on a Dana 44 with a ZJ Disc brake spring and seal in the stock Proportioning valve...can lock up 35's.Everthing else beneath that that is Awesome....
