I have a 91 jeep, now I'm not sure if I have the bad ABS or not, how do I know? and I was thinking of just pulling the fuse for now if I do have the crappy ABS? Mine has a black ball thing on the master cylinder, also the brake pedal is very hard, the truck stops fine but the pedal is harder then I'm use to, will just pulling the fuse help with the hard brakes? I did do alot of searching, do canadian trucks have the same ABS system as in the States.
thanks
thanks
