- Hartsville, South Carolina
Yes. It's a 1/4" plate that mounts between the Black Box and the transfer case. I think part of our issue is that we were mounting to a 241OR, as opposed to a 231. Even though Black Box said it would mount, the opening in the mount was not large enough to clear the 241OR. We ended up cutting a new mount from scratch.
There were also some issue with the length of the studs that were shipped with the Black Box, but that was solved with different studs.
I will say the box shifts easily, and having 2.72:1 low in 2WD is quite handy.
David Bricker / SYR
What did you use as the donor gears? Or did you just buy it all form them? I have a couple 231's from xj's laying around but from what I have ready they recommend the 6 planetary gear set. I have not researched that yet.
