jeeperjohn
- Temecula, CA
I only disco the battery when I weld. Never had a problem.
The other key note is to place the welder ground clamp as close as possible to where you are welding and in a fashion that any possible currents would not pass thru an area that has electronics in it!
I think that the whole removing the positive battery cable comes from using a TIG welder. The high frequency arc start on these welders does weird things to electronics. I've always done it after I fried a Corvette C5 computer. Oops!! :laugh:
Whenever I push the button on my TIG welder without striking an arc, my sprinklers come on for just a second then turn off again. WierdDing ding ding. High freq from tig machines can mess with electronics. I have never unplugged anything when welding on cars. Keep your work clamp close to the area that you are welding. The electricity will take the path of least resistance.
Probably the high frequency arc ignition circuit inducing a large amount of voltage in the long wires leading to the sprinklers, I'd bet. They work great as antennas for all sorts of signals not intended for them...Whenever I push the button on my TIG welder without striking an arc, my sprinklers come on for just a second then turn off again. Wierd
