I talked to Clayton before I chose iro and they couldn't tell me a bump stop height needed for their kit. The reason they say 6.5 inches is the upper arm hits the floor....
Not too impressed with my clayton 3link, all my links have slight bends to them now. Bent the top link when it hit the floor pan and at full stop on the steering with 35s the tires rub on the lower links. If i had to do it over again id go with Iron Rocks, the bends in the arms give more clearance for tires and the floor plan.
Iron rock runs 2x5/16 lowers. I have not bent my upper 1.5x.25 and it self clearanced on the floor pan. Been dragging lowers 2x.25 through the rocks they are heavily gauged but still straight. Seem to hokd tge weight of the rig well in tge rocks
Yeah Im hard on them, they get used as sliders and get hit against ledges. Good thing is since they are all straight links they are easy to replace with aluminum.
Evan I think your links are a little shorter which could explain hard use with no bending. I think iro uses 5/16 due to the bends they give the tube. Bending definitely decreases strength due to thinning the wall.
I haven't bent any yet thankfully
IRO 3 link here with random other parts (build as you go suspension). The links in the IRO kit work well, clear everything, and have been up to the abuse so far.
