hupo224
- Manchester, NJ
Hell everyone! On my third XJ here. It's a 1994 4.0/aw3/231 with power windows and locks.
I'm used to no gas or speedometer gauge on my last Cherokee. But I want everything in check with this one. I'm sure it is simple. The other day at the u pull it I had the option of a gauge cluster or a small window to fix the rear passenger door window. So I went with the window and fixed the glass today.
I did pull my cluster and clean the contacts on the back. The lights work on the dashboard and the water temp gauge is operational. However it does not drop down below middle and will randomly fluctuate higher when I am driving. I don't think it's a thermostat. Jeep does not overheat or smell at all. Just odd that the one gauge is kind of working and others are not.
Tomorrow I'm going to check all fuses over. I want to check all grounds as well. Can anyone tell me where each ground is generally located so I can go right to those points? The stereo is powered by a wire I need to attach on the ground. I don't know if it was done ghetto like that because of an electrical issue that is not powering the radio. But everything else works fine.
One more little gremlin is with the power windows. Right rear door does not roll down. When I changed the window today I put power right to the window motor so I could change it out. But there is no power getting to that switch. Nobody can roll down there window. I'm thinking the relay for my unlock switch may be bad. Is that located right behind the panel? People are capable of "stopping" me from rolling down there window. Telling me it could just be the relay for that switch. I been trying to find a diagram because I'd like to find out why the rear right door is not getting power.
Thanks for your time :]
