Okay, the final results are in!! DO NOT use the transmmisiion pan to take measurements!
DO NOT use the transmision pan to take measurements!
Whoever recommended that should be severely beat about the head and shoulders!
It isn't needed but, I checked the floor and it was
0° on both axis.
Valve cover
6° angled down to rear differential
Transmission pan
0°
NP242 drain plug
fill plug
spreader hole on 8.25"
5° angled up towards the TC output
It's close now and with the the
2° shims that is ordered it will give me the 3° that
GoJeep recommends if, I install them fat end to the rear. In the event that doesn't cure it then, I'll just remove the TC drop (gain an inch ground clearance) and the shims and I am still within 1°
Thanks for being patient with me boise49ers, Gojeep, ZacSquatch, Nickel101 and BlueCuda. I had asked a few questions before after performing searches and was royally flamed. I think one of the flamers recommended the transmission pan as a measuring location now that I think about it
