Ray H
- Falling Waters, WV
I know that some people have good luck pointing the pinion at the tcase output without a CV shaft. I cant explain that. Here is the geometry of it and how it should "theoretically" work. Just to add, the reason that the pinion tends to point upward when you install lift or arched springs in an XJ is because the center pin on XJ springs is offset to the front of the leaf pack, which is sloped upward on an arched spring, so the pinion will tend to point up unless its shimmed back to level. this site doesnt take spring wrap into consideration so you still should allow a degree or two for that. http://www.4x4wire.com/toyota/tech/driveline/
