Kingkong0192
- New Milford, CT
Looking to put a Mercedes 5 cylinder diesel (om617) into a cherokee. Looking to buy an 86-89 stick cherokee (To get around emissions.)
I figure it'll either have the AX5 or the BA-10/5 transmission. I want to swap in an AX15. Will that be a pretty much direct bolt in? I found the adapter from the om617 to the ax15. After i get those together will the AX15 just go into the jeep?
My other question is will any T-case (assuming the spline count on the tranny/tcase is the same along with the input shaft lenght) bolt onto the AX15? Or is there a difference between T-cases that bolted to an auto as opposed to a stick?
