- MilkyWay Galaxy
OK, this is a very specifc, what snake oil additive did you try and how did it perform question with two limitations. One, your story must be about it's use in an AW4, good, bad, or no difference is OK.
I don't care what it did in other transmissions!!!:twak:
Second, Did you have a slipping in forward drive first gear only when cold problem and did it help solve the problem or make it worse? I know I am not the only one that has an Aw4 that needs to warm up a bit (like 15 seconds to a few minutes, the colder it is, the longer it takes, and at 60 F it works perfectly and locks into gear in under 1 second) only when it is cold, like below 40 or 50 F, does it need to warm up first. I find that shifting into neutral or reverse speeds up the warm up process.
So all you other snake oil addicts like me with an AW4 snake oil story start posting those results!!!!! Please!
