lawsoncl
- North Idaho
FSM says solenoid #1 is on for reverse and first gear.
True, but with the TCU unplugged you have no solenoids engaged and you still get reverse.
x2. Your reverse clutch pack might just be garbage and the gunk in the old fluid was the only thing left holding it together.Possibly when you drained out the old fluid you might have done some wrong to it.. I am not an expert with the AW4 but I know with most autos when it is older and poorly taken care of when you go ahead and just drain out all the old fluid and replace it with new you sometimes have a bigger problem on your hands because some of that dirt in the old oil is keeping your tranny in check oddly enough.
lawsoncl,
how does the TCM gets its signal as to which gear has been selected? I am guessing the NSS, if that is true shouldn't he be working on it too, or does the TCU not care, and only looks at the VSS? I am thinking for some reason the NSS in Park, Reverse and neutral talks to the TCU, but I have not looked it up.
I've been going over the hydraulic application charts for '97 (Sorry, Chrysler doesn't have any service info for earlier years on their tech website). I believe however that the AW4 hasn't changed, ever. The only thing I could think of is a worn 1st/Reverse Brake is blown out somehow. It's only applied in reverse, and manual low (1-2). It's a clutch pack that locks the rear planetary carrier to the transmission case.
This thread is bout my 89 xj my friend started
I decided to scrap the old trans and probably the np242 t-case as well, Im done screwing with it, Its leaking again now. I have a 98 aw4 23 spline so ill put a 231 t-case on it but I know the wiring is different I think? something with the speed sensor or something? what do I need to do to make it work on my 89?
Aside from the spline count issue, the rear output speed sensor changed.
http://www.naxja.org/forum/showpost.php?p=243739279
http://www.naxja.org/forum/showthread.php?t=972069
http://www.naxja.org/forum/showthread.php?t=959184
I had the same problem as XJ atticus but mine was caused by driving the jeep around with little to no fluid in the trans (tranny line got cut and dumped most of the fluid on the ground while on the trail). I managed to limp it home and put some more fluid in it but it didnt fix the problem. Im thinking the tranny is toast but if there is a way to salvage it, that would be great!
