5-90 said:...the regular "silver" stuff has a nickel/aluminum base, and there is also a copper-base that I use regularly (for high heat.)
Robert 771 said:Ha! I knew it was hot, but the can of nickel grade in my garage says it's good to 1600*F. Yes, one THOUSAND, six hundred degrees.
Sorry, Jon, but if your rig's running hotter than that, you've got bigger problems than your antiseize.
Robert
Stumpalump said:You can use assembly lube in a pinch. Antisieze is molly like assembly lube.
5-90 said:Yeah, I know. I think the copper is rated up around 2200-2500, and I prefer to use it for front ends and anything anywhere near disc brakes - works better.
Probably as much personal preference as anything else - I just prefer to have as much room to play around as I can get.
The peanut butter stuff might be lubraplate. I don't really like the stuff after 15 years of cleaning and lubing the bifilars on a Uh-60.coastie124 said:We use nickle anti seize on all our aircraft. If your brakes are getting any hotter than a turbine engine then you've got problems. I've always said if it's good enough for aviation it's good enough for my truck. Can't just pull a helo to the side of the trail when it breaks down. Also we were using Mastinox and CA1000 which are antiseize products for use on the shanks of bolts. We've just replaced them with another product but I can't remember the name of it. It looks like peanut butter almost and isn't a carcinogenic which is nice. I remember we used to have an old work truck that had a 390 that would overheat. We would monitor the heat by shooting an infared thermometer through a hole in the floor board. I'm pretty sure the hottest it ever got was right over 1000.
What models do you work on?coastie124 said:No it's not lubraplate. We use that as a general purpose grease. Good stuff but not really an antiseize I don't think.
Continental aircraft engines call for a copper based antiseize called C-5A. It works quite well on the turbocharged engines.5-90 said:Yeah, I know - if it gets that hot, I've got bigger problems. It's probably one of those funny little habits I'd picked up from my granddad somewhere along the line. Since it hasn't caused me any trouble, I've seen no reason to stop doing it...
jeeperjohn said:What models do you work on?
jeeperjohn said:The peanut butter stuff might be lubraplate. I don't really like the stuff after 15 years of cleaning and lubing the bifilars on a Uh-60.
