- Up s*&^ creek with a paddle!
97 xj, 5 speed. Alternator appeared to be crapping out. 2 weeks prior my 00 was doing the exact same symptoms of gauge showing 14, then 12, then 9 after about 5 mins of running. On the 00 I didn't have time to test when I had finally grabbed my meter from work (was doing it after I picked up my meter) so I just put in a new alt and it has been fine since. So now my buds 97 does the exact same thing. We decide to do the 136 amp alt at the same time. Install goes fine. Redid the wiring (neg to chassis, neg to block, block to firewall, alt to starter, alt to fuse block with fuse, pos to fusebox) with 4 awg (I work at Best Buy doing car electronics installs so I have a good grasp on the wiring side). Took it for a test drive today and seamed great. Power windows going up better, sits at 14 and all was good. Then my bud goes to leave with the jeeps and after 30 mins of driving it goes back to the same symptoms and he gets it back to the house as the battery gets very low. Has new battery, alt, wiring. This time though he said the speedo stopped working and the fuel gauge also acted up. I fear this could be an ECU issue. Tried some searching but haven't come up with much. I have alldata at work and was going to start chasing wires but I figured I would ask for some pointers/common places to start. Thanks for any help.
