Jeff in VA
<---respect
- Richmond, VA
you've got 300# of discharge pressure, and no head in the condenser (or not enough to bring the fan on)?? Something isn't adding up there, unless the ambient temp is like -30F :laugh3:
Wellll, maybe, you'd have to work that out with a professional shop. They have expensive equipment for downloading R12 (thats the only legal way to remove it), most charge for the service and keep the R12 and send it to a recycling facility, do they get money for that, I don't know?Zoro said:I have all the new hoses for my system, I was considering coverting to R134A but I'm gona stick with the R12 so is there anyway to transfer R12 from a working system into my system? The only reason why I ask is because I've got 2 S10's I can take the R12 from...
Huh? When did that happen? Use of R12 is still legal in R12 systems, but the work must be performed by a licensed technition. The production or importation of R-12 is ILLEGAL, but the use of the remaining stockpile, including recycled R-12 is still legal as long as you follow the EPA rules. You can get a license yourself online, if you graduated high school and got better than a D in science, you can get a license to work on AC with an hour or two of study online.dfreeman616 said:use of R12 is illegal, just to make sure that's clear.
Huh? Who would design an A/C system to leak? What you say about the shaft seal makes sense, but you don't have leak refrigerant past the seal to get oil to it. I have had AC systems still have a full charge after 10 years and 175k miles of operation, I don't see how you can design a system to leak but only lose a small fraction of an ounce over a decade at 50-250 PSI of constant pressure the entire time. The shaft seal is one of the most common places for a leak to develop. I'm sure even the best working systems have a little bit pass that seal, I don't know if that is design or just the nature, you can't seal anything perfectly forever.dfreeman616 said:also, all A/C systems leak, and they're designed to do it. the question is how much? by the way, they leak at the shaft seal on the compressor, it's considered a controlled leak because the refrigerant has the lube in it that conditions the seal and shaft.
Yes and No, that is where the research comes in that I talked about. Some vehicles with R12 lines already had the special lined hoses to improve AC reliability, and they can handle R134a very well, also they've found in practice it was different than theory, the years of operating R12 impregnated the hoses with regrigerant, that prevent leaking of R-134a when retrofitted, basically the larger R-12 molecues plugged the porous holes and R-134a can't get by. But it is correct in many cases, the R12 line is not able to hold the R-134a because the smaller molecue with diffuse thru the molecular structure of the hose.dfreeman616 said:when converting R12 to R134a, you should replace all soft lines because (typically) the R12 lines are porus enough that they don't contain the smaller R134a molecules. you also need fitting adapters for the charging ports. R12 is more efficent than R134a, so a retrofitted system will never be 'good as new.'
use of R12 is illegal, just to make sure that's clear. also, all A/C systems leak, and they're designed to do it. the question is how much? by the way, they leak at the shaft seal on the compressor, it's considered a controlled leak because the refrigerant has the lube in it that conditions the seal and shaft. when converting R12 to R134a, you should replace all soft lines because (typically) the R12 lines are porus enough that they don't contain the smaller R134a molecules. you also need fitting adapters for the charging ports. R12 is more efficent than R134a, so a retrofitted system will never be 'good as new.'
Thanks for a more helpful reply. It lets me know how little I know about A/C. For some people, restoring A/C functionality is as simple as plugging a bottle in and letting it go. It seems that for most other cases, this job should be handled by a professional (or at least with someone experienced in such things advising).
While I'm not sure what kind of oil I have, it comes as part of a line of retrofit products, so I assume it's compatible.
Part of the instructions on the product I wanted to use say not to charge into a vacuum I believe. My system was just at atmospheric pressue as the entire contents had leaked out through a loose fitting.
Haynes and Chilton put all of the A/C stuff in a seperate manual, so it looks like I need another book.
The only way to remove moisture from a refrigeration/freezer system is to pull a heavy vacuum. The low pressure created by the vacuum causes any moisture in the system to "boil", allowing it to be sucked out.
Any time a leak develops in a system, there is a potential for air to enter. Air is synonymous with moisture. Once you get air in the system, it must be vacuumed to remove it. If you don't remove the air(moisture), the system will not function properly.
If the system has been opened up to replace any component, or has developed a leak resulting in "0" pressure in the system, air has entered. So, along with component replacement, or leak repair, the filter/dryer should also be replaced. This will insure removing the last bit of moisture that vacuuming may miss.
