Hi, That Dual Derale fan set-up is mine. It totals 4000cfm and works great. However its dificult to fit and pulls a lot of amps. I had to trim the plastic shroud it came with a lot to fit, especially near the sterring box. I notched the top to fit over the radiator top plate. Vertically it cover the entire radiator plus about an inch or so more. Horizontally it comes up a bit short but that works out becuase I needed the room on the steering box side.
Each fan will need it own relay a 10ga power wire directly to the battery becuase the amp draw is so high. I kept blowing fuses when the fans kicked on until I put a 40amp in there. Those 40amp fuse are hard to find. Running draw is probably around 20amp or so but it won't stay on that long unless your righ has other overheating issues.
