My Parts List for this swap, maybe it'll help someone.
I wanted near factory replacement leafs, heavy duty.
2 Rancho RS44148 Leaf Spring
The eyelets on each leaf are the same size, so you can't use a factory rubber kit for replacement bushings.
For Ubolts I went to NAPA.
U Bolt Grade 5 Steel Part Number 650-4023
7/16" thread 2-3/4" width 6-3/4" Length (Slightly longer than stock, good for the heavy duty thicker rancho leafs)
They come with high strength nuts.
Leaf Spring Shackle Bolts and rear stabalizer bolts to be replaced.
I went to
Tacoma Screw and they matched them nearly exactly w/ grade 10.9 bolts, nuts and washers. They didn't have anything with a nipple tip...
For the new leaf spring bolts I used MOPAR M14 replacements
PART # 34202118
The biggest problem was finding bushings for the rancho RS44148. I talked to the reps and they had no idea, they offered the part number for a bushing kit. The bushing kit they mentioned was for a DANA 35 axle (my axle), but it is no longer available! The bushings will fit the RS44148 leafs, but can't be found anywhere.
The only bushing kit that had everything, and was available was RS746. It is the same, accept the U-Bolts that come with it are for a Chrysler rear end. I bought it, because I don't need the U-Bolts. The Bushings fit.
The stupid thing is that the rancho engineers gave me the bushings part number needed, but it isn't serviced by anybody.
So part # RS476 works (bushings) U-Bolts that come with it are NOT for Dana 35, they are for the chrysler rear.
The second problem with RS476 is that there are multiple bushings and nothing to tell you where they go. There are 6 bushings with a thin lip and 4 with a thick lip. That is the only difference. I called Rancho again to ask them about it, they called me back. The rep said that, after talking to the engineers, they came to the conclusion that the different ones (thick lip) are "probably for the leaf spring shackles. Probably? It made "sense" because the leaf spring shackle bushings would be the only ones that are different. If you take all the eyelets into account. So that's what I am going with.
Kind of a nightmare. Hopefully that helps someone out.
I ordered the leafs off of Amazon, they mentioned that they came with bushings, but they don't.
Thanks for all the replies on this thread and good luck to anyone else with this problem.
