Adjustable Track Bar Body Mount Problem
Thayer
NAXJA Member #1255
Philly
I'm trying to put on my RK adjustable track bar, but it's not working. I drilled the hole bigger, so the 14mm mounting bolt goes through, but the holes don't line up since the rod end bumps into the body mount, right at the welded part (arrow in picture). What to do?
Nevermind, I'm such an idiot. For some reason, I thought it went above the mount when it actually goes under.
noresttill said:
mine didn't fit right stock, sdo I jacked up the drivers side a little
I was just about to say you might want to try putting it on the underside of the bracket..good to hear you got it though
