I have a 2000 cherokee and I want to add a manual switch to the aux cooling fan. Is there anything wrong with splicing the positive fan wire to a switch and then running a ground to the other switch pole? Would this interfere with the automatic operation in any way?
Could I run the ground to the accessory negative outlet and be fine? Would this mean it would use the accessory outlet fuse?
Thanks
My bad about putting it in this forum, I had a few windows open
Thanks
