emr1101
- Raleigh, NC
Okay so listen up you second gen XJ owners, you know how you cant use heat on the face/feet mode without running the compressor? And also (whether you noticed or not) even though the face/defrost mode is in white it still turns the compressor on? I dont know about you but id rather not use that gas unless i am getting some balls to the wall cold a/c, so for when i want to use heat to defrost (yes this does work, you have to use AC at first though obviously...) or even feet/face heat can i make a small switch to run to some line on the compressor that just makes connects a wire through the switch? if so which one? Im thikning a smaller one so that i dont damage the switch or over heat it... I know there are other wasy to do this (take apart switch panel, solder the connections, no thanks),but has any one tried this?
