Rawbrown said:
You cannot adapt an 8.8's abs into a jeep. An 8.8 has a single tone ring on the carrier. Jeep uses a sensor at each wheel.
the Jeep system is 4 sensor but is still 3 hydraulic (front L&R and ONE rear)
AND yes you can! I have done it myself on my brothers 90XJ with a 8.8 and the ABS does still work and will do it again on my ZJ. I was going to go the route of the tone rings on each wheel mess but that is a pain and costly once you get bushings for the 8.8 shafts since the OD area on the 8.8 shafts is smaller in that spot than the d35.
how I KEPT the ABS working on his XJ and will do the same on my ZJ:
my ZJ tone rings are 54 tooth per side and the 8.8 has 108 teeth on the ring gear 54x2=108!
his 90 XJ tone rings are 51 tooth but we decided to try it this way anyway. and later found out that the sensor does not count the teeth but just either sees a tooth or not.
I took the angle grinder and ground down EVERY OTHER TOOTH on the 8.8 ring gear tone ring making it 54 teeth.
We then wired both the Jeep rear sensors together left and right reds together and the ford sensor red all together and then if I remember correctly the left and right Jeep wires were yellow and wire those to the other ford sensor wire.
finished the install and bleed the brakes, then took it for a spin. the ABS light came on at startup like usual and then went off like usual! and didnt come back on as if there was a problem. I then slammed on the brakes and YES the ABS was STILL WORKING without the ABS light comming on! and it has worked perfectly since we finished the install 2 weeks ago.
as far as I know I'm the first to be able to CONFIRM that this way works for sure. at least it did on his Bendix ABS brake system. I will later do this again on my ZJ when I find the right 8.8 in the yards.
if you have any questions about let me know I don't get one here much since I'm a ZJ guy but I'll get back if yall have questions =)
