Boostwerks.com
- Colorado
So for the past 6 months its been a "one step forward, two steps back" sort of process for my heep. I rebuilt the transfer case with new bearings/seals/oil pump and upgraded to the 6 pinion planetary/wide chain setup at the same time.
I won't go into details with the little issues I've had, but what's been driving me nuts is that it grinds when I try to shift into 4 low (trans in neutral). It shifts fine however when the motor is off. Also shifting into 4 high is no problem. The linkage is fine as well (custom).
I've also been wondering if the problem has to do with the fact that I have a 96 trans and a 99 TC? I honestly can't remember if I had the TC is 4 low after the trans swap. Just not really looking forward to pulling the case for the 4th time this year :banghead:
Thanks for any help fellas. :kissyou:
