Bobby@Bullydog
- Texas
Ok another update
Pulled the Dist today to see if maybe the Gear was worn down because it only runs bad on idle...runs great off of idle. It was fine..barely any wear at all.
SO....with it running i pulled the wire off #1 Injector and the idle didnt change at all....revved it up and it studdered pretty bad so you know for sure cylinder one was down. Back to idle i plugged it back in. Revved it up and it revved smooth again...SO that tells me theres an injector problem at low pressure and I need to replace it.
Anyone got a spare set of injectors laying around?
