Bobby@Bullydog
- Texas
Yep gaps at .35
Any more ideas?
I dont think compression matters....2 cylinders just arent firing half the time.
Whats weird is it runs fine when off of idle but at idle it just sputters like crazy
I still get 16-18mpg on the highway
I replaced the Pick up coil and it didnt change a thing.i would say the magnetic pickup/stator/cam position sensor in the distributor and the cps need to be tested if 2 cylinders arnt firing.
Yep gaps at .35
Yea from what I have read up on the downstream o0 sensor, it does not affect the fuel mixture just checks to make sure the upstream is working. Now when I replaced it the first time it ran GREAT for about a week then BAM...problems Now that was with old plugs, cap, wires, rotor and all of that good stuff..and when i changed plugs they were pretty nasty so that could be an issue again and ive thought about it but i still think theres something deeeper. Ill swap out with a new o2 sensor this week and see what it does then.
Well I finally swapped ECMs with my neighbor and that didnt fix a thing
First code that comes up now is p0138 saying theres a circuit failure on the upstream o2 Sensor..so im gonna take it back to autozone and get a new one tomorrow.
Yea it was good but i went ahead and put another one in it. Didnt change a thing.did you check the fuse for the o2 heater curcuit?
