Kreutz
- Chicago, IL
have you checked the ignition module?
xuv-this said:that's wierd. the fuel pump is turned on by the starter relay/puter. i would haul it to the stealership if i could and get them to "take a gander at it". -not replace anything, just try to diagnose it.
badge714 said:believe the 95 uses just the coil,directly to dist. have you had the distributor removed from engine. can you hear the fuel pump click when you turn key on. it will click for 3-5 seconds to prime fuel rail. have you chenged the crankshaft position sensor on the bellhousing. give me a holler i have somethings & sheets that maybe of help. any extra info will behelpful. [email protected]
xuv-this said:also, i believe there might be a factory "security module" under the dash, as well. you would have to take that out , too. 91-95 is all basically the same stuff.
if you have no press. @ the rail, it's the pump or a bad wire or relay. tap into the wire to the pump. if it has power, it's the pump. the injector(s) are controlled by those sensors, not the pump.Nevada City Sparky said:OK, Mine's a 89 with a similar problem. All new ignition stuff. Engine cranks fine, I can hear the fuel pump working for 3 seconds while cranking, then it goes off. No pressure at fuel rail, but it will dribble a bit after an initial cranking (not squirt from scrader valve, but kind of a pfst and then a little dribble less than a 1/4 tsp.)
Sounds like Cam or Crankshaft Position sensor from what I read here. Ignition module was replaced just B4 I got it. So, which to replace first? By the way, its got 185K miles.
This has been an intermitant problem, coming and going. If its gonna start, it does on the first crank. If it doesn't start, it usually will later, although right now its dead.
I'd replace the fuel pump, but the last time I did that on a car (Landcruiser tank removal) I burned my house down (big boom), so I'd just assume look for alternatives.
I checked it this morning quickly before coming to work. Didn't check rail pressure, but when I turned key to "ON" position I got the requisite 3 second pump spin. I'm thinking one of these sensors is shot, either Cam or Crankshaft. From what I read here, if the positioner isn't working, it cuts off the fuel pump. Please correct me if I'm wrong.xuv-this said:if you have no press. @ the rail, it's the pump or a bad wire or relay. tap into the wire to the pump. if it has power, it's the pump. the injector(s) are controlled by those sensors, not the pump.
Nevada City Sparky said:I checked it this morning quickly before coming to work. Didn't check rail pressure, but when I turned key to "ON" position I got the requisite 3 second pump spin. I'm thinking one of these sensors is shot, either Cam or Crankshaft. From what I read here, if the positioner isn't working, it cuts off the fuel pump. Please correct me if I'm wrong.
langer1 said:When you first crank the engine the ECU sets timing buy counting pulses from the CPS and then turns the coil, injectors on and the fuel pump back on.
You need to check for spark and fuel pressure when cranking, if you don’t have spark check CPS and cam position sensor in the distributor.
Nevada City Sparky said:OK, think I got it. So, if I have no spark, chances are its one of these sensors. If I do have spark, likely a weak fuel pump. Make sense?
langer1 said:Yes but don't jump to the fuel pump as the problem, you have to think fuel problem, several things can cause no/low pressure. Could just be a plugged filter or busted hose.
