- MilkyWay Galaxy
I must be loosing it. I have done the brake light switch on my 85 and 87 Xjs and the master cylinders (more than once), which are all working. I have also previously worked on the brake light switch on the 89, but I had an odd problem last time (unfortunetly I have forgotten the exact details), which I am now trying to resolve. Last time it seems I did an emergency fix-switch replacement (maybe 2 years ago now-?), and left out the old sleeve (if it was even there before?), and this time I bought a used set up from a member, with the sleeve, bushing (1-?), what was left of it, and the white plastic spacers, bolt, nut and lock nut.
I tried installing it per the haynes manual pictures, and also used my other jeep, 85 as a guide, but the sleeve diameter is too large to fit inside the master cylinder push rod, but is the right ID for the bolt and the right OD for switch. So I pulled out some tubing the right diameter to fit inside the MC push rod end, cut it to length same the one I bought used, and except for tiny bit of slop (but nothing like I had before), got it assembled, and it looked good, and right. Then I connected the electrical connections, and find the brake lights are now stick on all the time?
So I thought maybe Autozone screwed up, and dropped by the store, and checked and the push rod is not replaced when replacing the MC, and the HL switch I had was the right one or so it seems, as the part number and picture for 87 and 89 are the same.
Has any one else ever run into this before??????
This jeep was all stuck when we bought it, except for a cattle guard bumper, and mini Uhaul trailer hitch.
Also this one has the cruise control, so it has two, 2 wire connections on the brake switch, second one being for cruise control. The OD on the sleeve I got from the XJ is 9/16" OD, while the one I made for the smaller hole in the MCylinder push rod end is 1/2" OD, and fits the push rod perfectly. The 9/16" sleeve will not go into the push rod.
So I have 2 or 3 problems here. One is the hole size, one is the sleeve, the other is that even with the smaller sleeve, the brake switch is pushed on hard enough to be on all the time!!!!! So something very odd is going on with the push rod on this beast???? :smsoap:
I can't figure out how it ever worked before. When I started on it again this week, there was no sleeve at all. just the bolt and too much slop, but it some how worked for a year or more, and got through inspections until I knocked off center fiddling with the ECU connections due to a no start-CPS problem, which is now (knock on wood), fixed. When I discovered the brake lights were out, I reset it, but re-noticed the slop, and decided to go back and try to fix it right.
But now I am really scratching my head. The used parts off the other XJ I got in has a sleeve that fits the AZone switch, and the bolt, so I suspect they not the problem, but 100% sure. The MC rod seems to be too long on the outer end, and even with the custom, smaller sleeve I made and tried, thew push rod is too large on the far side and activates the brake light switch all the time.
HELP?????? Ideas, how did this odd push rod get into what looks like a normal stock 2WD jeep non modded jeep?
