- MilkyWay Galaxy
Sounds like you are down to the ICM, and or C-101. Did you swap the MAP sensor back out again? I am not sure you need a good map sensor to get spark, but you said you swapped it, and still it did not start, so...
I don't have the right info with me to tell you much more here. The HV coil resistance data you posted sounds OK, IIRC. Have you ohmed out the primary HV wire just to make sure it is not busted inside, lost conductivity? It should be about 1000 ohms apx, for standard HV wires? Or about 0-1 ohm for special wires.
