I need a new system including cat and downpipe. Some of what I need to know is contained here:
http://naxja.org/forum/showthread.php?t=1114938&highlight=exhaust
Yet, I need to go further into the details. Most of my Xj's have been this same vintage (i.e., Renix) so, I have history with these. Here are my concerns:
1 - Prefer stainless for quality & longevity. Seems like my only choice would be custom because, I cannot locate a full system from any after market company.
2 - The current design for the down pipe is wrong. Everything I see (as well as one I have owned) features the "hill" at the transmission cross member to prevent the down pipe from grounding against the cross member. Years ago, the down pipes did not feature this elevation change and I never experienced any incidence of contact between the down pipe and the cross member. You just have to use the exhaust flange bracket for the down pipe/CAT interface that fits into the cross member.
3 - My current cat has holes in the welds on each side. These have resulted in an increase in my fuel economy that I would like to keep. Does anyone make a high-flow cat for the Xj? Presumably, some of the stroker people can answer this question.
4 - I am willing to change the exhaust manifold if necessary but, I would need to be certain the benefit exists.
Help if you can..
Help if you can..
