Canyonman
- Northridge,CA
1987 jeep wagoneer limited 4.0,4 speed OD automatic,Trans cooler,comfort and power shifting switch,select track full time 4WD 242 T-case,Factory tow package 5000lb with 7-way plug,one year old AC Cold air,Gauge pkg,400watt amp with new speakers,New headliner,custom lights on hatch back,Optima batt still under warr,Front dana 30 and rear 8.25 axles are out of 2000 XJ,I have Original window sticker- $24,000.00
2" lift with spacers in front and add a leafs in rear,31"x10.5"R15 bfg all terrains and full size spare,locking gas cap,leather rapped steering wheel,
sound deadining material added under all plastic panels,fog lights,limo tinted windows with quality tint not purple stuff.
All things listed now, as new, are within the past 3 years
The engine has about 20,000 miles on it$1500.00,the shell has 215,000 miles,Distributer new when I installed engine.$250.00
Borola header with "high clearance" catiletic converter and flowmaster cat back.$650.00 I would have used on my new jeep but won't fit.
The engine runs perfect and super cool with no smoke or oil burning.
New radiator,starter,Batt cables,Alternator,water pump,air box,AC hoses and charged$500.00,front seats are from newer XJ,headliner,Axles from 2000 XJ,Master cylinder,Brake booster,Brakes are in great shape,
The transmission was rebuilt with HD parts seals just 5,000 m ago $900.00
only cause a spring failed,T-case was rebuilt 7 years ago.wood trim 6 years ago.
U-joints in drive shafts.
Vacume lines,coolant bottle,trim parts anything thats suspect I've replaced.Just lubed up windows,T-case oil,engine oil,air filter,Trans oil/filter just before Moab Oct 08
I've been fixing everthing I can for the last 6 months.
The only things that don't work are the power door locks (weak) they try.
cruise control (loose wire).The paint is better than my 2000 grand cherokee(thin).The body is not perfect but otherwise it is very reliable.
This has been the best car I've owned, Hands Down.
17 years and I've only been towed two times.Just did the last off-road trip to the 25th ani in moab Oct08 with modified version of my baby.
Yes all the money I've spent why would I sell it?
I bought a 2000 cause I wanted a different color but now that the economy is bad I'm regretting it.The newer model is not built as well. This jeep is ready for a 4-6" lift and 33's.All reciepts for parts and work done.
Even just for the parts,Borola header,flowmaster,engine and new parts,batt,Rear axle is better than dana 35.interior.
Registration is till Jan 2010 and passed smog easy.
Asking $2000.00:doh:
Greg 818-438-0665 9AM-11PM
More Pictures on photobucket http://s704.photobucket.com/albums/ww46/canyonmans/?action=view¤t=woodyforsale005.jpg
