the ford D44 "hd" is low pinion.. that was found on like 75-77 camper specials or something. the minty axle is the 78-79 F250 HP44, and yes you can use those outers.
you can run outers from whatever you want- ford, chevy, dodge.... just be aware that 8 lug 44 stuff is super expensive. getting custom drilled 5x5.5 shafts for the 60 will probably end up being cheaper if all your 5 lug ford outers are already in good shape.
