- Bakersfield, CA
The digressive valving is horrible. Can work on a slow speed rock crawler, but not on anything that wants to see some speed getting to the trails. It's purpose is to be stable for slow speed then soften for hits. We need almost the opposite since we run at speed. We need stronger valving for speed to absorb the big hits without bottoming. There used to be the perception that real soft springs were best for rock crawling to allow good flex, and the digressive valving could add some stability. But now stability is usually valued over flex, so stiffer springs work well, and we go faster also requiring stiffer springs, so shock valving for slow speed is pretty insignificant. If the shocks are stiff enough for decent high speed stuff, they still work fine for slow speed.
