Stang5lgt
- Parker, CO
That thing is pretty sick!! :thumbup:
Stang5lgt said:That thing is pretty sick!! :thumbup:
Gojeep said:Been great following your project.
Above, are you talking about the bolt or stud that holds up the cross member on a stock setup? That just screws out which everybody does when fitting a transfercase drop and replaces it with a bolt.
As for the cooling, having thought about fitting the transcooler below the radiator like I have just done and used a Taurus fan.
Full write up about it on my site. www.go.jeep-xj.info
WheelinJR said:The taurus fans are two speed and I believe are rated at more CFM than a mechanical.
The place my Jeep gets warm more than anything is when I am sitting and no air is flowing thru the Jeep with the mechanical fan. The fan spins slow at idle so it won't move much air, and of course as soon as you get moving the temp settles right back down.
The nice thing about the electric is that it spins constant so you're always getting a good cooling effect.
I would say a Taurus fan, or a good pair of smaller slimfans like these is your best choice
http://cgi.ebay.com/ebaymotors/Procomp-10-1250-CFM-Radiator-Cooling-Fan-street-rod_W0QQcmdZViewItemQQcategoryZ33600QQitemZ330099552259QQrdZ1QQsspagenameZWDVW
You will be able to go a bit wider but only to the steering box gets in the way.
I am partial to two procomp 10" fans over one Taurus fan because your stock radiator is only about 11" tall so your focusing all of the fan blade area onto the radiator and nothing is hanging below. My plan is to use a couple of these and one of these Zirgo variable temp switches
http://cgi.ebay.com/ebaymotors/FAN-TEMP-SWITCH-ZIRGO-DIGITAL-ANALOG-STYLE-20-250_W0QQcmdZViewItemQQcategoryZ34202QQitemZ260096612853QQrdZ1QQsspagenameZWDVW
Just some food for thought.
Gojeep said:I can guarantee that those 10" fans will NOT work. Just to replace the mechanical fan you need a minimum of 2500 CFM PLUS the A/C fan which pulls around 1800 CFM.
The Taurus fan is very reliable and the only failure I heard from from a guy that just hard wired it so it ran all the time! The second-hand one still lasted a couple of years but not designed to run that way and is a stupid idea to do that anyway.
I found that having the cooler out of the airstream of the radiator has made a big difference so far and was always suspected that the auto was getting hot first and then putting more strain on the cooling of the radiator. One that it has to deal with hotter air flowing over the core but also the in tank auto cooler heating the coolant as well.
Taurus Fans are used a lot in anything from off road buggies to hotrods and muscle cars. I have looked at for years putting in a deeper radiator but you first have to narrow the width to get between the frame rails and then cant go low on one side due to the steering box getting in the way. You end up with a smaller radiator area rather than bigger. Just look at the what I have been told is the factory setup for a 4 cylinder 2.46L.
2xtreme said:Fifo,
I am pretty sure my worm drive winch takes up significantly more room infront of the radiator than your Warn does. And living in the Northwest I have not had any issues with it either on or off road, summer or winter. As long as everything is working well I don't think your going to have any issues with the size of the radiator.
I am curious as to why you are adding all of that extra weight of the tube for fenders?
Michael
FiFo said:GaryTJ said we could harden the metal by heating it all up, and then rapidly cooling it, so naturally I tried to get Tom to heat it up so that we could throw the whole thing into his bath tub, but he wouldn’t go for it.
Dirk Pitt said:Unfortunately, it isn't that simple. Plain carbon steel will not harden that way.
There is a process for hardening plain carbon steel, but I doubt you have the equipment in your bath tub.
You would have to get it much hotter than any kitchen oven could get it anyway.
