Okay instead of doing the cable actuator thing I figure what the hell I'll rig it up to where the fork slides the collar over permanently, I know someone suggested this. So I fixed it where the fork stayed over to the engagement side all the time, (can't disengage) and left the vacuum lines on there to give it a bit of assistance (constant vacuum pressure in 4WD). So I test drove it (part-time light being on constantly only slightly annoying), I started going around a corner and started hearing a horrible grinding noise and my part-time light started flickering (it was still trying to disengage even though there was no way it could be forced too!) I pulled it up in 4WD and it went away ( I assume vacuum pulled the fork/collar over even further since it can only go that way)
Then I tried making a "T" with the vacuum hoses so no matter if I was in 4WD or 2WD the vacuum would still be pushing it towards the engage side(constant vacuum pressure to engage). It seemed to work okay but when I went from 4WD back to 2WD it started grinding again and trying to disengage (light flickering again even with constant vacuum to the engagement side), I figure it's the collar grinding on the axle shaft? So what does this mean that my collar is totally fried and has to be replaced?? This like just happened, all of a sudden one day the 4WD would not engage. I checked on a new vacuum thing for the axle and the stealership said $250.00! The fork is all the way over and it still does not stay engaged so the cable thing would not have worked anyway.
I'm out of ideas.
I'm out of ideas.
