jpmaniac87
- Orlando, FL
Anyone know where to get these things?! If it's the dealer, you got a part number? This is my '91 XJ. I put swap my 242 out for a 231 and lost them in the transition... Thanks!
The front output yoke bolts,(4), are part # 6029582 at your local stealership. They should have them in stock. Cheers.
Ok, Stealership wanted $12 PER BOLT!!!!
So I went to Ace, got 4 5/16"-24x1¼" (actually, they gave me one wrong one that must have been in the wrong box, so I've gotta swap that) and 4 washers. Works great and they were $.55 ea. A 1/2" box wrench is all you need. Thanks for all the good info guys
8mm fits mine better than 5/16". I bought a 6-point ratchet wrench from Mac just for dealing with these bolts. I believe it fits the retaining bolt in the cross shaft in the diff as well.
