Thank you buddie . Its for people who would like to beef up there factory axles.jeepme said:I am sure a lot of people said "why would anybody make a super 35 kit" but they do, and it sells, so why not a Super 8.25.
I agree, and I also brought that up back then and Mike mentioned doing 4.88s for it. Personally I would like to see 5.13 or 5.38 to make it really worth it.Rawbrown said:Who really cares about needing 33 spline shafts for the 8.25 till its really necasary. kinda a moot point since 4.56's is the lowest you could go. I don't think to many people are breaking 29 spline shafts on 33"s and 4.56 gears...
Don't ya think. maybe when someone comes out with some 4.88 gears for the damn axle it'd be worth going to 33 spline shafts, but until then, your money is better spent somewhere else...
And your point being? The c-clip is a non-issue if you don't break, and isn't that why someone would want to have a much stronger shaft? A lot of people give the 8.25 a bad rap, but what many of them don't know is that the main body of a stock 8.25 shaft is actually thicker than a Dana 44 shaft. What makes it a weaker shaft is the lesser diameter of the shaft at the splines and the neckdown. The stock 8.25 shafts neckdown a huge amount compared to the Dana shafts. But thats why this is promising. The beefier main section of shaft means that the amount of neckdown can be dramatically reduced (shaft thickened) in that area. So add a 33-splined shaft to a housing with larger tubes than the Dana 44, and a pinion much larger than the Dana 44, and I'll gladly accept the fact that it has c-clips.RCP Phx said:And dont forget its still a C-clip axle!
As someone else pointed out they make a Super 35 kit. But... the market for the 8.25 is probably a lot bigger than you think. The 8.25 is found in the following:jeepnuts311 said:why would superior make a super 8.25 kit anyways? im a little confused. as ryan has already pointed out, 4.56 is the lowest you can gear, and what other vehicles did the 8.25 come with? not many (libbys and what else?....small market) it seems like they wouldnt make any money on the kit expecially working with another company who has to make a special carrier/locker for it
they will probably be standard pitch, so somewhere between the 1.31 of 31 spline shafts and the 1.50 of 35 spline shafts. do a little searching and you can probably find the diameter for the 33 spline Super 44 shafts, and it's likely the same.DirtyMJ said:What size would these 33 spline shafts be? Anybody know/say?
I'm not a C8.25 fan. But maybe because I've never owned one.
Are you talking about the shaft diameter at the splines? I would guess the same diameter of a Super 44 shaft with 33 splines. That would be something I could ask Mike when I talk to him. I called a few times today but didn't get him.DirtyMJ said:What size would these 33 spline shafts be? Anybody know/say?
DirtyMJ said:If they're the same diameter as the 33 spline ones for the D44 - I don't really see the point.
The shafts will be quite a bit stronger than the R&P.
BrettM said:they will probably be standard pitch, so somewhere between the 1.31 of 31 spline shafts and the 1.50 of 35 spline shafts. do a little searching and you can probably find the diameter for the 33 spline Super 44 shafts, and it's likely the same.
EricsXJ said:Are you talking about the shaft diameter at the splines? I would guess the same diameter of a Super 44 shaft with 33 splines. That would be something I could ask Mike when I talk to him. I called a few times today but didn't get him.
EricsXJ said:You would think that in many cases the driveshaft u-joint will be the weaker link.
Haven't been able to contact him by phone. Secretary said he was at some show somewhere... I'll try email.Mike L said:Any news?
DirtyMJ said:The reality is I just figure there's better axles out there that can be had cheap. Welding a couple spring perches on ain't a bad thing - you can fix that damn pinion angle.
