- sacramento
Post for your free stuff here, get good Karma.
Zachandandy and moparmansfield. I could really use a set of tires for my stock rig if your tires seem road worthy. Right now mine are pretty weather-cracked and would prefer to not drive on them if possible. With that said, I will be willing to meet up on mon in hollister since you live there moparmansfield and Zachandandy is plannin on wheeling there. If you dont have room to truck them to hollister, I understand.
I have many 87-96 body parts.
side glass with rubber seals.
stock springs
97+ front stock flares black.
2 alloy stock rims with ok tires(87)
stock lcas with ok bushings
oem steering with good rod ends
are the springs coils or leaves?
You are all the way in Hollister huh? I might try to look for something more local unless we get a serious parts train to sacramento.
If you are willing to ship, I will take the JCR steering box spacer. My zip is 93444. SHould fit in a small flat rate box, or if wrapped in a flat rate env.I have some stock parts
99 front coils
Track bar
Rear sway bar with bushings and axle brackets
Also have a brand new jcr steering box spacer i don't need
Concord CA
