raymond32j
- riverside, cali
I have a 01 Jeep Cherokee 4.0L with 135k miles. I had been having problems starting the jeep, had to turn the key 3 times to prime the fuel pump for it to start up. So I finally had some extra money to replace it. The jeep starts right up but the codes for the check engine light came up P0351/P0352/P0353. So then i went to go replace the ignition coil and put new spark plugs in as well. So the jeep starts right up and drives, however the check engine light came on again and now the code is P1391. I have been searching these forums furiously and I noticed and the symptoms for this code is usually a no start or drops after 2000 rpms which my jeep does not. My jeep drives perfect, no misfires from what I can hear/feel. So could this still be caused by the CPS? I really need this fixed and the check engine light off for it to pass smog as the 3 months are already up and I don't have enough money to keep replacing parts. I am just ready to give it to the local mechanic and have them diagnose it for me as I have limited tools and limited auto knowledge. So did anyone had a problem like this? Should I replace the CPS? Thanks guys, Im just stuck right now.
