SanDiegoOverland
- San Diego
Read again:
Could the FPR, or a voltage drop, loose electrical connection or changing ground to the fuel pump.
49 psi while running. 32 while off. got it. Missed that part.
But then the next time he hopped out at home it stayed up at 49psi. Weird.
StylerG, when you noticed the psi was down at 32, did you also notice the same symptoms you originally mentioned? Did you notice if they improved once the psi got up to 49?
