2000 Jeep Cherokee Fuses
Junction/fuse block (inside kick panel)
Fuse #1 is the large 25A on the top of the left column
Fuse #15 is the large 25A on the top of the right column
Fuse #1 power outlet
Fuse #2 cigar lighter
Fuse #3 left headlamp
Fuse #4 left headlamp
Fuse #5 right headlamp
Fuse #6 Dash lights (switches, controls, gauge cluster)
Fuse #7 license light & the left side turn, parking, marker and tail lamp
Fuse #8 Spare
Fuse #9 compass, sentry key, headlamp delay module, instrument cluster
Fuse #10 transmission range sensor, duty cycle evap/purge solenoid, radiator fan relay, a/c clutch relay, o2 sensor up/downstream relays, back up lamp switch
Fuse #11 transmission control module, power train control module, automatic shutdown relay, fuel pump relay
Fuse #12 instrument cluster, combination flasher
Fuse #13 Spare
Fuse #14 power mirrors, rear defogger & switch
Fuse #15 passenger power lock/window switch
Fuse #16 cargo lamp/switch, courtesy lamps, radio, instrument cluster, under hood lamp, transmission control module
Fuse #17 radio
Fuse #18 power mirror switch, driver power window/lock switch, heated seats
Fuse #19 starter motor relay
Fuse #20 trailer tow harness & trailer turn relays
Fuse #21 horn(s)
Fuse #22 rear wiper switch & motor
Fuse #23 right side marker, turn, parking and tail lights
Fuse #24 Spare
Fuse #25 shift lock solenoid, a/c heater control, abs controller, abs controller relay, blower motor relay, blend door actuator
Fuse #26 airbag control module
Fuse #27 airbag control module
Power distribution center (under the hood)
Looking at the PDC from the front of the vehicle, the bottom right mini fuse is #16, the one above it is #17, the top one in the column is #18.
Fuse #19 is to the left (of #16)
Fuse #16 under hood lamp, transmission control module, radio & interior lights
Fuse #17 O2 downstream relay
fuse #18 coil rail & injectors
Fuse #19 headlamp switch & data connector
Fuse #20 combination flasher
Fuse #22 fuel pump relay
Fuse #23 brake lamp switch
Fuse #25 fog lamp relay
Fuse #26 power amplifier
