drewkeen
- Nashvegas, TN
I started with a 1998 Cherokee 4.0 AW4 donor and swapped it into a 2000 Cherokee 2.5 AX5 that had a locked up engine. Before the swap the clusters in both worked fine. The engine now starts and runs great, but the instrument cluster is not happy. With the 2.5 cluster it said "no bus" in the odometer display. I had 2 4.0 Clusters (from a 98 and a 99) that I swapped in and they did not say no bus, but none of the gauges worked at all. I swapped both of the engine bay harnesses over, but left the stock wiring behind the dash. Any ideas?
