- Roanoke VA
Im tired of getting 12mpg(mixed driving) on a stock XJ, my trail rig does better turning 35's!
A little history;
94, AW4, NP231, all stock. 289,000 on the chassis and tranny
I just installed a newish motor, its a 96 block with only 90k on it. My last engine was burning 2 quarts a week. It only got 12mpg as well(mixed driving).
When I installed the new engine I replaced all of the sensors(CTS, MAT, O2, MAP, CPS, new distributor). I replaced the fuel injectors and the FPR. I also cleaned and lubed the three connectors on the ECU and the bulk head connector. I added NGK plugs and Accel cap/rotor. The exhaust is new, with a new cat. New fuel filter.
I cleaned the throttle body and the intake before I installed it.
It runs very well, strong acceleration, smooth idle, plenty of oil pressure.
NO CODES, NO CEL!
Any ideas? I covered about everything when I had the engine out of it but there has been no change. I know its not the motor. I was getting 16 mixed in my 96 XJ with this engine before my teenage son sent it to Jeep heaven. I have owned this XJ for 10 years and it has never gotten good mileage. I'm thinking it might be time to swap ECU's and see what happens.
This jeep drives so good, I'm not giving up on it
A little history;
NO CODES, NO CEL!
