winterbeater
- Royal Oak, Michigan
Do you have access to a timing light? Most vehicles are not adjustable, so it's not worth it to buy one, but you could see for sure if you have steady consistant spark.
I have a new fuel pump. I checked the fuel at the rail and there is pressure 40psi when I first tuurn the key
I have over 120psi per cylinder compression
I have spark at all 6 cylinders
and I have air
I think the timing may be out but not sure how to change it or if it is even possible
so I have all the things I need to run but it does not run
I tried changing the ECU but that did not help
I also unplugged the CPS and then there was no spark and reconnected it and the spark came back.
I TDC the crank and the rotor and cap line up with #1 cylinder
I also tried quick start and that did nothing so it’s not a fuel problem cause I could smell it on the plugs when I pulled them
here is a link to a video of me cranking it over the first bit you can here it start to fire on maybe one cylinder but it only did that a couple times
http://www.youtube.com/watch?v=MvD2TnRkWY8
I then disconnected teh IAC and this is the second video
http://www.youtube.com/watch?v=FRWW4K-piVA
Let me know if they dont work I can take some more videos
Thanks for all your help!!!!!!!
NO not in the video but it does the same thing even if someone is spraying ether in
I have checked the TDC and it lines up with the spark plug #1
I pulled the plugs after cranking and the #2 was very wet and the others were damp
put the plugs back in and un hooked the injector wires and cranked it over and it ran for a second and it sounded good like the timing is fine. so I pluged the injectors back in and cranked nothing. unpluged the injectors cranked and it ran for a second again. this is the longest I have herd it run.
What controlls the injectors?? and I guess I need to look into a NOID light right??
I have new plugs in Bosh platinum pluss
it still has the factory alarm in it I found that out when I put the new batt in and the light started flashing but I unlocked the drivers door and the light stopped flashing.
I pulled out the IAC last night and cleaned it. I slid back the black collar and cleaned inside too. is the rounded end supposed to slide or move at all mine does not move?? is there any way to check it??
I do have a fule presure guage I will take some reading and post them
