fordtech
- Amherst NY
blkbird95 said:Hi,
I own 2 Thunderbirds, so I had to step in with some facts...
Ford produced the T-Bird with a 5.0 HO from 91-93 only, and also in the Mercury Cougar of the same years. The Fox Body T-birds (88 and older) never got the HO. The MarkVII did. The upper intake from the TBird HO is the same that was later used on the 94 and 95 mustangs, but the lower is the same as any year HO. The accessories are tighter to the motor in the T-birds and 94-95 mustangs, so this would be a benefit over the fox body accessories when swapping into such a confined space. For more info on T-birds check out www.tccoa.com. I'd love to swap a 5.0 into my 92 XJ, but I keep blowing them up in my 95 T-bird (swap of coarse!)
Thanks,
Brad
I know the newer body mustangs(94-) and markvii used pretty hefty electric fans.... not sure about the old stangs. Try to get the engine harness and pcm too.... you will need a manual trans pcm.
The truck 5.0 or 5.8 would be cool, but they are tall!!! Arent the zf's kinda large?? I would say a 5.0 HO with ZF (if it would fit) or c-6, and BW t-case from a f150 to keep it simple....
