sardo_67
- western CT
i like those brackets you made. i sent you a PM about them
When I put the LS2 XJ together I just shortened the lever on the tranny to give me the correct throw length and welded on the cable tab from the AW4 so the stock jeep cable would attach. I then modded the jeep cable mounting bracket and bolted that to the random tab sticking off of the trans bell housing (the tab is seen in your pic just below the cable mount).
You can look at the thread in AdFab and there are pictures of my solution there. I also modded the gates on the stock shifter and everything lined up perfectly except there was an extra gate between "1-2" and "3" on the shift indicator.
Looks good. Can you show what did you do for the water pump spacers? I also used a car pump, but I yanked the pulley and pressed the truck pulley back on. It was a real PITA and I don't want to do it again if the pump fails.
How is Your project going? Any updates on your HVAC system?
i dig those brackets!! can you go over what you had to modify on the power steering pump?
also info on the water pump adapter and those truck to car manifold injectors as well if you can. i'll be copying a lot of what you did here, any idea on what you are doing for gauges?
Run a full tailpipe in 3".
