blackxjeep
- Rochester Hills, MI
Well, I know the APN header has been mentioned, discussed, dissected, and hailed here many times over. In addition, the tech depth of this issue is actually very well documented in this site, but there is still one last bit that I'm hoping the real "experts" can help me out with here. My situation is as follows:
I have a 2000 XJ Sport that has the non-California emissions system on it. As far as I can tell, everything is bit for bit the same as the 97-99 models in terms of exhaust. Obviously, I'm stuck in the coil rail boat, but that's OK with me.
Now, I have heard things about the APN header not working with the 2000's and up, but the general consensus is that this is primarily due to the stupid emissions system on the newer motors. All things considered (I do have a coil-rail casting head, but not more than 1 cat, and the normal O2 locations, etc), do you guys with this header think I have a good probability of a successful install with little to no extra mod work required?
And before someone brings up something about a better design on the exhaust manifold making mine less prone to leaks and cracks, it should be noted that although it took one hell of a lot of work, I still managed to crack this sucker. Maybe I'm special, maybe it's just a 99 carryover, either way, it's not too bad now, but I don't want it to get any worse.
Inquisitive first post is inquisitive.
