John D
NAXJA Member # 788
- Rockford, Mi
So, I basically finished up doing the 5.3L / 4L60E swap last September. One of my goals was to maintain the OEM Jeep instrument cluster to save the appearance of a stock Jeep.
I ran the Jeep PCM in tandem with the Chevy PCM. I spent some money and time plumbing the 5.3L with Jeep sensors and everything should have work, it didn't. You see, the gauges are fed (I think it starts in '97) by the signals being multiplexed through a buss going from the PCM to the instrument cluster. Even so, my theory was that the proper sensor would feed the Jeep PCM and send the signal to the dash. Unfortunately this wasn't the case. It appears in my case, that the Jeep PCM is going into a sort of auto-shutdown. Countless hours of research (wire diagrams, web searching, interviews with Mopar experts, and seat of the pants troubleshooting) have proven that it is not an auto-shutdown. What happens in my case is, when you go ‘key-run’ all of the Jeep gauges light up and read accurately. When you go ‘key-run/start/run’ the gauges "freeze" wherever they are and will not go up or down until it goes ‘key-off/run’ again. The computer drops communication with the instrument cluster through the start-run cycle. I have spent countless hours over the last six months trying to make this work and I cannot. It is unfortunate because I really wanted my dash to look factory.
I decided with warmer weather and the prospect of driving the Jeep again approaching it was time to give up and go another route. I bought a set of AutoMeter Phantom gauges, and a blue, amber, red and two green led lights from Summit.
Original Jeep cluster minus the pointers and electronics behind.
Disassembled.
Gutted the Jeep cluster, and painted black.
Fabbed up the new gauge mounting panel, painted black.
Test fit into Jeep cluster.
Test fit gauges into panel.
Fitting bezel around gauges.
LEDs mounted.
Gauges mounted in the dash.
Overall, I am happy with the way it turned out. I would be happier if it was the OEM cluster, but sometimes you just have to move on.
Disassembled.
LEDs mounted.
