Old October 15th, 2020, 21:43
acodylavin acodylavin is offline
Post transmission adapter for the BA 10/5
Hey Y'all
been wanting to do a 4.5 inch long arm lift kit from RC but i have the dreaded peugeot transmission. unfortunately no long arm lift kit works with my tranny.
iron rock offroad sells the peugeot trans adapter but im not sure if it would work with the rough country lift.
anyone ever done this before?
unfortunately swapping the transmission out is not a option for me.
adapter
https://www.ironrockoffroad.com/prod...n-adapter.html
lift kit
https://www.roughcountry.com/jeep-xj...-xj-4wd-735436
Old October 16th, 2020, 07:35
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: transmission adapter for the BA 10/5
Just stick with IRO for the lift. Way better than junk country.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old October 16th, 2020, 09:45
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I don't see how it wouldn't work, but I haven't tried it. Assuming swapping the trans isn't an option due to rarity in Canada?
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old October 16th, 2020, 09:50
RCP Phx RCP Phx is offline
I would also recommend something other than RC. TNT's kit fit the Peugeot trans and is a good kit.
Old October 17th, 2020, 12:19
yeah borderline impossible to find... and if you do find one its a million dollars and missing 3 gears... besides current tranny is still going great (knock on wood) so no need to swap it out
Transmission pressure port adapter? Talyn OEM Tech Discussion 0 March 7th, 2010 16:34
Torque specs - Transmission tail housing/adapter JeepFreak21 OEM Tech Discussion 7 September 9th, 2008 23:37
Oil leak - oil filter adapter or transmission Slonopotam OEM Tech Discussion 4 January 7th, 2007 15:12
transmission/x-fer case adapter rguy Wanted: Private Party Only 0 September 22nd, 2006 18:52
4x4.5 to 6x5.5 adapter smilesyota Modified Tech Discussion 16 May 2nd, 2006 14:52
