Ralph77
- East Coast
So I want to run something by you guys to see if I am even close to being on the right track. Or if my XJ will burst into flames. '00 with an automatic and 4.0 by the way.
So the goal is to upgrade the alternator. Got a guy, does this for a living, who says he can take a stock alt and maybe get as much as 150 amps out of her. I want a straight bolt in. That is why I am not doing the GC one that guys do.
So figure I will run 4 or 2 gauge battery cables depending on where we end up amp wise. My understanding is that 150 amps and down I can get away with 4 gauge. Anything above that should go with 2 gauge.
We sell everything I need to make battery cables at the Napa I work at. My old boss use to make battery cables for customers. Says we can whack them out like nothing. If I don't do that I am going to go with XJwonders.
So you get rid of the fusible link with something like this:
https://www.amazon.com/Woljay-Bolt-...pID=51iXp7lyJ9L&preST=_SY300_QL70_&dpSrc=srch
I want to set it up in front of the fuse box in the engine compartment like I see other guys do. My understanding is that you use a fuse 25 amps higher then your alt puts out. Figure some military terminals and should be good to go.
At the moment all I am running is factory fog lights but the Jeep did not come with them. So I am using a fuse tap in the fuse box in the footwell for a 12 volt run source for the switch, have the relay by my cruise control with a 20 amp fuse using an inline fuse holder to the battery.
I want to wire in an Ext Idle switch, might want to put lights on the brush guard that I hope to get installed some year, maybe some lights in the back, install the headlight harness I have (purchase from jhc7399), and install one of those retractable under the hood lights I picked up awhile back.
So instead of having a rats nest of inline fuses, trying to fit things by the cruise control near the battery (you all know how tight it already is there), relays scattered all over the place not to mention fuse taps for 12 volt run sources for switches figure I would try to set up an aux fuse box and put all the relays in one place. Oh by the way want to use factory fog light switches for the lights front and back. At the moment thinking in the space over by the power brake booster.
I have read that it is best to put the aux fuse box as close to the battery as possible. So I am wondering if over by the power brake booster is a good idea. No matter what gauge I run for battery cables thinking that one should be 2 gauge.
So I figure between all the relays I figure 4 20, maybe 30, amp fuses. Then 4 10 amp fuses for 12 volt run sources for switches plus what ever amp I will use with the under the hood light. It has a built in switch and will not need a relay. At least I am pretty sure.
So that puts me over 100 amps which seems to be the limit for most aux fuse boxes. Except this one:
https://www.amazon.com/gp/product/B07CLS96RD/ref=ox_sc_act_title_2?smid=A1EQP448COWZL4&psc=1
But this will require 2 cables from the battery cause it is really 2 100 amp max fuse boxes in one. I am thinking I should put one of those circuit breakers in front of that fuse box.
https://www.amazon.com/gp/product/B079GQ5H6F/ref=ox_sc_act_title_1?smid=AH1IN68PWF3TU&psc=1
So I am thinking I run one cable to the circuit breaker and 2 short 2 gauge cables off that to the fuse box. Any idea how many amp that circuit breaker should be?
Then there is the jhc7399 headlight harness. I want to rewire it. Make the wires longer so all that can go with where the rest of the relays and aux fuse box end up. Think I found all the locking terminals I need to rewire the headlight harness.
https://easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/187open_barrel.html
I would use the biggest gauge wire I could when I do this. Anybody think this will negate the performance of the headlight harness?
I also want to use some of that braiding that you see on the battery cables. Something like this in the appropriate size.
https://www.summitracing.com/parts/...MIqcui9LT32wIVArnACh1hPAFNEAQYASABEgKkTfD_BwE
Not to mention all ends would have heat shrink on them.
So I think I touched on everything.
So am I clueless or at least in the parking lot at the ballpark? LOL. Be honest. I can take it. LOL. I want to do this right and electrical is not one of my strong points.
Sorry I am kind of all over the place with the post and looking forward to any and all opinions, ideas, etc.
